Will NH D15 fit in Zalman Z3 plus case?
TuboGaming
7
I am going to buy a new pc and probobaly cool it with the noctua nh d15 cpu cooler and was just wondering if it will fit in this cheap but feature proof case.
I did some research.
The towerdimensions are: 192 x 465 x 430mm (W x H x D)
And the cooler dimensions are: 150 x 161 x 165 (W x D x H)
As you can see it will be quite close since the height of you fan is 165 mm and the width of your case is only 192 mm without keeping in the gaps between mb and case.
so what about something like z11 plus. will it fit there
zalman isn't listing the cpu cooler height limit in their web page
