Jlg823 Distinguished Dec 26, 2013 478 2 18,815 Jan 6, 2015 #1 Will the Noctua NH-U14S http://www.newegg.com/Product/Product.aspx?Item=N82E16835608041&cm_re=Noctua_NH-U14S-_-35-608-041-_-Product Fit into this: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146075&cm_re=NZXT_210-_-11-146-075-_-Product
Solution Dark Lord of Tech Jan 6, 2015 No it won't fit. CPU Heatsink Support 160mm Height 165 mm of cooler
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Jan 6, 2015 Solution #2 No it won't fit. CPU Heatsink Support 160mm Height 165 mm of cooler Upvote 0 Downvote Solution
Jlg823 Distinguished Dec 26, 2013 478 2 18,815 Jan 6, 2015 #3 No it won't fit. CPU Heatsink Support 160mm Height 165 mm of cooler What about the Hyper EVO 212? I need a better cooler! So recommend any you can. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Jan 6, 2015 #4 The 212 EVO is 159mm and should fit. Upvote 0 Downvote
Jlg823 Distinguished Dec 26, 2013 478 2 18,815 Jan 6, 2015 #5 The 212 EVO is 159mm and should fit. My only concern is the pins on top of the Evo 212. Because that may make it impossible to fit. Upvote 0 Downvote
