trio1989 Honorable Jul 14, 2013 49 0 10,530 Jul 14, 2013 #1 i have bought a noctua dh14 se2011 by mistake i was meant to get the normal dh14 and now it wont mount on my 1155 motherboard? will the NM-I115X fix my problem?
Solution cin19 Jul 15, 2013 Yes, the kit will fix your problem, you can check the company website for info. Or you can return the 2011 one and buy the regular one.
cin19 Titan Mar 14, 2011 15,722 218 112,340 Jul 15, 2013 Solution #2 Yes, the kit will fix your problem, you can check the company website for info. Or you can return the 2011 one and buy the regular one. Upvote 0 Downvote Solution
trio1989 Honorable Jul 14, 2013 49 0 10,530 Jul 15, 2013 #3 cin19 : Yes, the kit will fix your problem, you can check the company website for info. Or you can return the 2011 one and buy the regullar one. Cheers will order it as its only £5 saves all the hassle and waiting around thank you for the reply very helpful Upvote 0 Downvote
