Custom Built PC with AMD processor and board.
I have had the machine for about a month and it has been working great. I powered my machine off last night and this morning it would not turn on.
I attempted to change outlets, use the direct power on mb and tried other hardware in outlet. None of those solved issue.
Normally I would assume that it is a psu issue however the led lights on the mb are working properly.
Only notable thing about environment is that I keep my room cold, in the 50 degree F range last night. Could it do damage if it got too cold?
Hope that you all can help. Thank you in advance.
