Will NVIDIA GEFORCE GTX 1050 TI WINDFORCE OC 4GB fit in my pc-case?
Sep 5, 2018
5
Hello, I am planning to buy the NVIDIA GEFORCE GTX 1050 TI WINDFORCE OC 4GB to replace my old Geforce GTX650. The thing is that this card seems kind of big for my case, and due to the fact that is expensive I thought to ask you experts first. In addition, the PCI-express slots and the PCI slots seems to be really close to each other and I am afraid that the new graphic card's fans will approximately touch the sound card, which is in the adjacent PCI slot. The type of my motherboard is Gigabyte B75M-D3H. I also send you photos from inside the computer.
Every answer will be really helpful. Thank you in advance!
eRoyPe
mZLTPe
mZLTPe
http:// Inside my case
http://
http://
http://
http:// this link shows my case
Yes, according to the manufacturer website your case can fit video cards up to 400mm lengths. That is plenty. your card is 229mm long, therefore that shouldn't be a problem at all. In your case you might have to remove some HDD cages in the back, but it will work and the case seems like it has plenty space.
Thank you!!
Well if it collides with the HDD, I'll probably move it at a higher, or lower shelf. Thank you
