Will Nzxt hue+ led strips work on MSI mobo ?
gamingboX23
Hello everyone i bought new motherboard with cpu and ram.
Over year ago i bought nzxt hue+ and now that i have new motherboard i want to know can i control those led strip with motherboard software.
I am aware that motherboard has 4 rgb conectors. Motherboard is MSI Z370 carbon pro.
Thanks.
To use the led-strips, you'll need a the hue+. For the Hue+ you will need a not used power supply cable, thats basicly it.
And if you can mount the hue+, the ledstrips will also fit, because the only need to be connected to the Hue+ and not the mobo.
In short: yes it'll work if you have a powersupply with an extra cable to connect the hue.
If you later decide to also buy nzxt aer rbg fans, then you will need atleast 2* free 3pin/4pin connectors on your mobo.
Im not sure though that the strips can directly be connected to your mobo or even controlled by mobo software.
According to my search around the internet, that is not possible, but with the Hue+ it will work.
