I had the same question before i bought mine but fortunately I have a friend that already tried the Sentry 3 and was told it didn't fit. The controller fills the space properly however to get it to work you have to remove the bay bracket and screw it in as it's to shallow to reach the retaining clamp. I ended up going with the Sentry Mix 2 instead because it's full length and though it's not as flashy it gets the job done.
