E evilister13 Aug 2, 2018 1 0 10 Aug 2, 2018 #1 I'm going to upgrade from i3 4130T for lighter gaming and casual use .Are they compatible?
Solution Rogue Leader Aug 2, 2018 evilister13 : I'm going to upgrade from i3 4130T for lighter gaming and casual use .Are they compatible? No its a completely different socket. The ONLY CPU upgrade you can get for that system is the i5-4570T. https://support.hp.com/us-en/document/c04323331 Thats the only better processor that it was available with, and you are limited by the hardware and BIOS to what HP sold it with.
yeti_yeti Reputable Apr 29, 2017 414 4 4,965 Aug 2, 2018 #2 No they are different gens and are not compatible, you will also need new ram, if you wanted to get the pentium (or any new cpu) Upvote 0 Downvote
J jay32267 Champion Mar 16, 2017 10,709 1,330 56,940 Aug 2, 2018 #3 It doesn't give any indication that it is.....here>>> https://support.hp.com/us-en/document/c04323331 Also....being it's an HP prebuilt....it can be hard to find the needed info on the MB like WHAT will it actually support and what BIOS versions go with which processors. Upvote 0 Downvote
C Calvin7 Titan Feb 19, 2013 11,725 334 76,490 Aug 2, 2018 #4 Those CPUs use different sockets, (LGA1151 and LGA 1150). Upvote 0 Downvote
Rogue Leader It's a trap! Moderator Dec 22, 2014 32,729 2,812 113,640 Aug 2, 2018 Solution #5 evilister13 : I'm going to upgrade from i3 4130T for lighter gaming and casual use .Are they compatible? No its a completely different socket. The ONLY CPU upgrade you can get for that system is the i5-4570T. https://support.hp.com/us-en/document/c04323331 Thats the only better processor that it was available with, and you are limited by the hardware and BIOS to what HP sold it with. Upvote 0 Downvote Solution
