I was playing devil may cry 4 special edition; When I tried to change texture quality settings from Med to High, the Power went out at the same moment I pressed enter to make the change.
Any possible damage ?
Possible... but highly unlikely.
Certainly not enough to worry about.
If you have frequent power issues, you might buy a UPS.
It need not be expensive, and allow for perhaps 5 minutes of run time.
That will get you through power glitches and give you time to shut down gracefully if power is out for a while.
No it wont damage your gpu. There is no difference in shutting down pc or unplugging from the wall etc. Only problem you can have with some errors on hdd/sdd and maybe problem with OS but I never experienced that either in my 20 years of owning PCs. And power outages here are pretty common.
