for cartridges with the printing matrix on the bottom:
if you leave them open to air for a very long time they will dry up on you. however, if you are only going to leave them sit for a few months then wiping the matrix with rubbing alchohol seems to work great at getting the surface residue off.
best advice.... dont buy more ink than you need to.
