B buzzhead0 Honorable Dec 23, 2013 50 0 10,630 Dec 24, 2013 #1 I have a intel celeron g540, 4gb ram, win 7 ultimate and very bad graphics card nvdia but I can run farcry on low settings and resolution. If I get a amd radeon 6670 gddr5 will I be able to play in better settings and resolution ??
Solution Jared Jensen Dec 24, 2013 Yes, upgrading to a 6670 will increase your graphics performance substantially but i would recommend getting a new card if possible.
Jared Jensen Honorable Dec 7, 2013 341 0 10,960 Dec 24, 2013 Solution #2 Yes, upgrading to a 6670 will increase your graphics performance substantially but i would recommend getting a new card if possible. Upvote 0 Downvote Solution
B buzzhead0 Honorable Dec 23, 2013 50 0 10,630 Dec 24, 2013 #3 Jared Jensen : Yes, upgrading to a 6670 will increase your graphics performance substantially but i would recommend getting a new card if possible. THANK YOU SOOO MUCH .. SO ARE YOU SAYING THERE WONT BE ANY PROBLEMS WITH GAMES (with cpu...) Upvote 0 Downvote
