Will RCA Splitter work in pc?
antoniodireito
85
On my PC I have a headphone jack and a microphone jack. I'm trying to plug my headset into both. At my work they have a Stereo "Y" adaptor cable. Instead of aux the cable has two RCA plugs. If I plug my headphones into the 3.5mm cable, which splits into two RCA connectors, will it work in the 2 audio plugs on my PC? Thanks
Okay, it sounds like you've got a headset that has one TRRS connector that carries both the mic and the headphone signals, correct?
If that's the case, you need an adapter specifically designed to separate the two functions. Here is one such adapter:
https://www.amazon.com/StarTech-MUYHSFMM-Headset-Splitter-Adapter/dp/B0058DOWH6/
