[SOLVED] Will RTX 3090 fit into H500M
Sep 18, 2020
Hallo everyone,
I have a question, hope you can help me. :)
First of all, I have this configuration:
Intel Core i9-9900KS,
Aourus Z390 Master Motherboard,
Corsair H115i CPU Cooler,
Corsair A1600i digital ATX Power Supply 1600W,
Aorus GTX 1080, 8GB GPU,
4x8GB Kingston HyperX Predator 4000MHz,
Samsung 970 Evo 250GB + WD 1TB,
Cooler Master H500M Case.
Now, what I would like to ask you is, should I cahnge my case or any of my componets(beside my GPU 😀) in order to put inside a new GPU, Aorus GeForce RTX 3090 XTREME?
Thank you in advance :)
Your case can take a very long graphics card up to 412mm.
The 3080fe is 285mm.
Here is a photo of it next to a 3090fe:
https://www.neoseeker.com/Articles/...-rtx-3080-fe-performance-review/#&gid=1&pid=1
I might guess that3090fe will be around 335mm.
No doubt there will be some huge aftermarket versions.
Bottom line is not to worry about that.
As to changes, if you do not have a 4k a high refresh monitor,
Such a monitor will be the first thing to change.
Hallo everyone,
On Gigabyte website for the card size it says "TBD" (to be determined). Looks like the models listed for Asus and Msi are between 300-350mm and your case can take a max length of 412mm. I don't think you'll have a problem but still, not certain.
https://www.gigabyte.com/Graphics-Card/GV-N3090AORUS-X-24GD/sp#sp
Reactions: Phaaze88
