I have an all-in-one liquid cooling module that has a double-length radiator and two fans.
Using the long bolts included to attach this to the case on the inside proves to be quite noisy due to all the vibration:
I want to use shorter included bolts to attach the fans to the radiator, and use rubber screws to attach the whole thing to the case:
My concern is that the rubber screws (of which there will be 8) will become brittle over time and fail, and then the whole radiator+fans block would crash down onto my GPU.
What do you guys think? Is this idea safe or not?
