[SOLVED] Will RX6500-6800xt work on my motherboard
Felipeuen
7
My motherboard is Z370 Aorus gaming 7. LGA 1151
My processor is I7 8700K.
My GPU just stopped working.
I am thinking about buying a RX 6700XT, or similar.
Will it work on my setup or should I just stick to Intel Geforce GPU?
Also, If I buy a RX 6700 or RTX3060, my setup should be fine with no bottleneck right?
Power Supply 750W
Thanks!
Yes any of those cards should work with your computer. They connect via the PCIe bus and are all cross compatible. With a 750 watt psu you should have plenty of power to feed any of them.
Nvidia is the company that makes Geforce.
No matter what you do you will always have a bottleneck. Either your CPU is bottlenecking the GPU or vice versa. Depending on your resolution and target FPS your 2017 CPU more than likely will be the bottleneck on current generation GPUs, but not terribly so.
Reactions: Felipeuen
