Will Sapphire R7 240 DDR5 1GB work on my pc ?
Rashedul366
39
Can I install Sapphire R7 240 DDR5 1GB on my pc ?
Intel celeron 430 @1.80 Ghz.
G41-M7 motherboard
3 Gb ddr3 win xp 32bit
dell 18.5" moniter resolution 1366x768
i dont want any problems after installation . 😉
Motherboard has a single PCI-E x16 and will be compatible, although the CPU is a bit weak and you may not get the full performance of the GPU.
