Will single channel Memory cause stutter ?
  • Thread starter Thread starter Deleted member 1560910
  • Start date Start date
D
Guest
I have this MSI GT Series GT73VR TITAN PRO-NE1080 i haven't received it yet. It only has one single 16gb would buying another stick run games better ?
No, infact mixing a new stick of ram might not be compatible especially if it's not the exact same stick with the exact same timings. What resolution will you be gaming at? I doubt you'll use more then 12gb of ram while gaming. Wait untill you recieve your machine and check ram usage, adding more ram shouldn't have a gaming performance increase.
my question is would would duel channel run games better than single ?
Benchmarking is different than actual game play for example 2 rigs with one having single and the other having duel both could get around 100 fps but one being less smoother experiance is the real question. getting 100 fps with stutter doesnt make for a good experience even though on paper it looks great
yeah, you do not get stutter from single channel RAM...
if you're getting "stutter" you have a fps drop.
what I was trying to say is, while there are situations where dual-channel RAM does make a little bit of difference, gaming doesn't really care
