will spdif to 3.5mm work on xbox one
chirufan1
110
Hi,
will spdif to 3.5mm work on xbox one.I am looking to buy desktop speakers with 3.5mm input(these are cheaper than rca input speakers).My question is, if i connect my xbox one to the speakers via spdif to 3.5mm wire will I get sound output.
Hi there chirufan1. Hmm, both x-box 360 and xbox one support exclusively s/pdif interface, therefore will not work with analogue speakers. You either need a receiver, that will convert the signal, or dac interpart, or digital speakers, with s/pdif input connector.
Very good choice for You is getting the eSynic® DAC Digital SPDIF Optical Coaxial Toslink to Analog Stereo RCA L/R 3.5mm Jack Audio Converter Adapter or native digital speakers, like logitech Z906, or others with s/pdif input.
This one works great with xbox 360 and xbox one. Tested it on both systems.
hi uplink-svk,
yeah the brand you mentioned above is not available in India and the ones that are available are over my budget.
my solution costs 2500 where as your system costs 4500 with the dacs available in India
chirufan1 - there are no active speakers with built-in aplifier and S/PDiF connector. They all rate from around 200 euro/dollars.
Very good are Logitech Z906. My personal favourite are older Logitech Z-5500, which I find heavily superior towards Z906, but not as nice.
