Yes. But only in either push or pull, not both. Not enough clearance at the top of the case with the motherboard installed. I've got mine in reverse push and it works like a dream
Hmm okay, thanks alot! Do you have the Sabertooth Z87 though? Or do you have the Asus Z87 Plus?
I have the Plus, but the two motherboards have the same form factor. What fits with the Plus should fit with the Sabertooth.
Ok! I will buy it and see, thank you very much for your help!
