Will system volume info on usb affect bios?
pcnewbie1010101
19
I'm not sure if other people have this problem too, but on my usb, there is a folder called system volume information. You can't get rid of it even if you format it. If I use this usb to flash my bios, will there be any problems? Should I use another usb, or will this one be ok? Thanks.
It's probably formatted in NTFS, every time you format it in NTFS windows makes it and it doesn't matter if it's there, takes only few bytes too.
Hi, I’ve got the same issue - did u manage to update bios with this file on it? Cheers
