Will the AMD FX8320 go in my build with no problems?
jldk6
179
Specs
Motherboard: 78lmt - usb3 rev 4.1
Gpu: Gtx 660
Cpu: Does not matter since im replacing it
Psu: cx600m corsair
Ram : 8gb 1 stick
If there is a problem putting that cpu in any help to fix that problem would be appreciated.
Thank you in advance :)
What about heat problems and things like that?
Um ok my bios version is F1 the newest is F3 can i ask how to update it?
I heard that bios flashing can break the motherboard.
I should also add that i dont have a usb stick on hand.
If you have never flashed a BIOS, you should likely use the Gigabyte @BIOS flashing utility from within Windows.
You should also contact Gigabyte and verify the Rev 4.1 will support the FX-8320E --- it is not on the CPU support list for that revision, but likely should (and will) be on the list soon.
I hope it works on my motherboard because i cant afford a new motherboard :/ I sent them a ticket to check if it can.
Alright i fixed it now im just waiting on gigabyte to tell me if the cpu works my my board.
We know the regular FX-8320 is qualified, and it's the same price as the 'E' (as of now).
The -E is simply a newer chip (and likely higher-binned). Though the base speed is a bit lower the Turbo speeds are the same.
I suggested the -E because it's flying past the older model FX-8320 in OC'ing, is 95w, and would be a near-perfect solution for a 4+1 phase motherboard like the Gigabyte.
What CPU are you using, now?
Im using an fx 4100 and its bottlenecking my 660 hard
also i have 0 plans of overclocking
and i can only afford this one http://www.amazon.co.uk/AMD-FX8320-Edition-4-0GHz-Socket/dp/B009O7YU56
so i dont think i will be getting the -E will the one in the link still work with my pc? And also would the stock heatsink for it be ok?
