Will the c7 fit on a micro atx motherboard/ H81M-DGS From Asrock
AlanZhouGaming -
Commendable
Sep 4, 2016
92
Will it fit on the H81M-DGS Motherboard from asrock and not block any ram slots. I mean the CRYORIG C7 "A MINI ITX CPU COOLER" thats what im scared of "MINI ITX" im scared that the c7 will not fit my motherboard ASROCK H81M-DGS and also block the ram slots!
Help PLZ
https://pcpartpicker.com/builds/by_part/Lbhj4D
C7 is much better than stock and quieter , mainly used in ITX , but fits on all types of boards with no memory spacing issues.
http://www.cryorig.com/c7_us.php
Zero Interference
A Cooler That
Fits Anywhere
The CRYORIG C7 has a specifically designed width and length that safely complies with the CPU * Keep Out Zone . The C7 is a guaranteed fit, with no RAM or PCI-E card interference period.
*The CPU Keep Out Zone is a design guideline set by both Intel and AMD. It is set around the CPU, and dictates no components over a certain height can be placed there.
http://www.cryorig.com/c7.php
[video="https://www.youtube.com/watch?v=Otk0zgdLKyg"][/video]​
Wait so even if its a micro atx it will still fit?
What is your case?
The C7 is a downdraft cooler designed for cases with restrictive room for a cooler.
It is not very effective.
In a low profile home theater case, that may be what you need.
If your case is a conventional M-ATX tower, your will be better served with a cryorig H7 for the same price.
