I have these components:
AMD Ryzen 3600 6 core @ 3.36 Ghz
Thermaltake Litepower Gen 2 650W Power Supply
Corsair 16GB (2x8GB) CMK16GX4M2A2400C16 DDR4 2400MHz Vengeance
Thermaltake Versa H18 Window Micro Case
Corsair Cooling Hydro Series H60v2 with illuminated LED CPU Cooler
Cooler Master MasterFan 140mm MF140R Adressable RGB Fan x2
Gigabyte GeForce RTX 2060 Super Gaming 8G OC Graphics Card
I'm wondering what MOBO will work well with this system?
https://www.umart.com.au/Gigabyte-X570-UD-ATX-AM4-Motherboard_52397G.html
https://www.umart.com.au/Asus-Prime-B450M-A-mATX_44995G.html
Would a cheaper MOBO effect the GPU/CPU performance?
Is there a better MOBO you would recommend?
Should I get more ram speed or is 2400Mhz enough?
Thanks
Thanks
