M MCMoartea Reputable May 13, 2015 19 0 4,510 Jun 8, 2015 #1 I had enough noise from FX-8320 stock cooler and i wanted to replace it with CM 212 EVO and I'm not sure if it will fit in my case, Delux ME879(435H, 410L, 192W) as I can't find anywhere what's the maximum height for a CPU cooler for this case.
Solution RCFProd Jun 8, 2015 In a case below a width of 200mm It's likely not to fit (well). Delux ME879 case dimensions: 435 x 410 x 192 mm Look at another options like the Raijintek Themis or Cryorig H7.
RCFProd Expert Ambassador Dec 8, 2013 12,605 29 56,990 Jun 8, 2015 Solution #2 In a case below a width of 200mm It's likely not to fit (well). Delux ME879 case dimensions: 435 x 410 x 192 mm Look at another options like the Raijintek Themis or Cryorig H7. Upvote 0 Downvote Solution
