Will the Cooler Master Hyper 212 fit into Corsair SPEC-ALPHA Carbide ?
Partyparrot
24
So box is 22cm wide and Cooler is 16cm tall. I think it will be a tight fit, but I am also concerned about the air flow. Should I consider water cooling because of the size ? I'm not planning to OC much, but to save some space in the box. Also a bit concerned about the RAM. MoBo Is ASUS Prime Z270-K
The case specs listed on their product page:
Technical specifications
Dimensions (L x W x H) 518 x 220 x 474 mm
Maximum GPU Length: 380 mm
Maximum CPU
Cooler Height: 156 mm
Maximum PSU Length: 190 mm
Expansion Slots: 7
5.25” Drive bays: N/A
3.5” Hard Drive Bays: 3
2.5” Drive Bays: 4
Cooling Layout:
Front: 2 x 120mm (2 x 120mm LED included)
Top: 2 x 120mm
Rear: 1 x 120mm (included)
Radiator Compatibility:
240mm: Front only
120mm: Front, or Rear
Integrated dust filters for front and bottom intakes
Front I/O Panel includes: USB 3.0 port (2), Three-Speed Fan Controller, Headphone and Microphone jacks, Power on and Reset buttons.
2 Year Warranty
say otherwise.
You may also want to read through this...
Maximum CPU
Expansion Slots: 7
2.5” Drive Bays: 4
Cooling Layout:
Top: 2 x 120mm
240mm: Front only
2 Year Warranty
say otherwise.
You may also want to read through this post. Likewise you may want to go through this gallery and pick up a cooler that they've all used.
If you're in doubt while you yet have access to other brands, then pick up a Cryorig H7 cooler.
