A ali13245 Reputable Oct 14, 2014 108 0 4,690 Nov 2, 2014 #1 Title says it all. One thing to note, i am using an MSI Z97Gaming 7 motherboard. Any responses will be greatly appreciated. Thank you.
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Nov 2, 2014 #2 If its got a spot for two 120 or 140mm fans then it'll fit. Usually at the top of the case or the front. Upvote 0 Downvote
TheDualshock Honorable Jan 24, 2014 975 0 11,660 Nov 2, 2014 #3 Seems like the Define R4 supports the H100i (under Cooling system): http://www.fractal-design.com/home/product/cases/define-series/define-r4-black-pearl The H100i is a 240mm radiator : http://www.corsair.com/en-ca/hydro-series-h100i-extreme-performance-liquid-cpu-cooler In short, it should fit your case. Upvote 0 Downvote
A ali13245 Reputable Oct 14, 2014 108 0 4,690 Nov 2, 2014 #4 thank you all for the fast responses, and yes my case does support 120 and 140mm fans, however what I am asking is that will it work with my MSI Z97 Gaming 7 motherboard installed in the case? Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Nov 2, 2014 Solution #5 Of course. Upvote 0 Downvote Solution
