Question Will the Corsair Icue 465X RGB Mid-Tower fit my top radiator?
Oct 20, 2019
5
I'm looking to get a new case and really wanting the Corsair Icue 465X. My main concern is will it fit both my 360mm (front) and 240mm (top) radiators. I'm scared of the RAM getting in the way of the fans/radiator up top.
Specs:
Ryzen 7 2700x (Thermaltake Floe Riing 240 for cooling)
Gigabyte X470 AORUS GAMING 5 WIFI
Gigabyte GeForce GTX 1070 Ti GAMING 8G (Thermaltake Floe Riing 360/with nzxt Kraken for cooling)
Corsair Vengeance DDR4 RAM 8gb x 4
Rosewill Gaming 80 Plus Gold 1050W
Seagate 2TB FireCuda Gaming SSHD
Link to case here
The 240mm radiator with fans won´t fit with your RAM
Dimensions of the Thermaltake Floe Riing 240:
FANDimension:120 x 120 x 25 mm
RADIATORDimension:270 x 120 x 27 mm
25mm + 27mm = 52mm
It´s 20mm from the tops case to the motherboard´s beginning and another ~20mm till the RAM begins
Eventually you would have problems with the motherboard´s "Thermal Armor" of the backplate as well.
