A alexoler2002 Prominent Dec 26, 2017 23 0 520 Jan 16, 2018 #1 Hello i have a vs550 however will it be enough to power a gtx 1060 and an i3 6100 i will upgrade the psu in about a year.
Solution Dark Lord of Tech Jan 16, 2018 CX450M or CX550M would have been a better choice , but the VS can run it.
S sizzling Titan Oct 18, 2006 27,218 3,268 112,240 Jan 16, 2018 #2 Is it new or used? The wattage is ok but the quality is poor. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Jan 16, 2018 #3 alexoler2002 : Hello i have a vs550 however will it be enough to power a gtx 1060 and an i3 6100 i will upgrade the psu in about a year. Yes it's more than enough power for that setup. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Jan 16, 2018 #5 More than enough power. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Jan 16, 2018 #6 http://www.tomshardware.com/answers/id-3603559/corsair-vs550-bad-rig.html Upvote 0 Downvote
A alexoler2002 Prominent Dec 26, 2017 23 0 520 Jan 16, 2018 #7 I am asking if it is enough to power a 1060 Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Jan 16, 2018 #8 Easily enough Upvote 0 Downvote
S sizzling Titan Oct 18, 2006 27,218 3,268 112,240 Jan 16, 2018 #9 It's enough and if brand new should be ok for a while. It's not a PSU I would buy as you can get better quality for little extra cost. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Jan 16, 2018 Solution #10 CX450M or CX550M would have been a better choice , but the VS can run it. Upvote 0 Downvote Solution
