Long answer:
Case supports CPU cooler height: 148.5mm / 5.8 inch
Noctua height (with fan): 125 mm
If your RAM stick gets into way, just put it into another slot further away of CPU cooler.
Long answer:
In your case, where you only have 1 RAM stick, it doesn't matter in which socket you put it. If you had 2 or more RAM sticks then you have to check the MoBo manual about RAM sticks placement.
