wiyosaya Distinguished Apr 12, 2006 915 1 18,990 Oct 20, 2015 #1 I do not see the E5-1680 V2 listed on the supported CPU list for the ASRock X79 Extreme 6. Does anyone know if the E5-1680 V2 will work on the ASRock X79 Extreme 6 motherboard? Thanks.
Solution k1114 Oct 21, 2015 It's compatible with other E5 1000v2 cpus so should work with them all. But same socket does not mean much as far as compatibility goes.
overco Reputable Sep 1, 2015 241 0 4,710 Oct 20, 2015 #2 They are both the same socket type so I wouldn't see why not. Upvote 0 Downvote
k1114 Titan May 2, 2010 14,236 93 75,540 Oct 21, 2015 Solution #3 It's compatible with other E5 1000v2 cpus so should work with them all. But same socket does not mean much as far as compatibility goes. Upvote 0 Downvote Solution
wiyosaya Distinguished Apr 12, 2006 915 1 18,990 Oct 21, 2015 #4 k1114 : It's compatible with other E5 1000v2 cpus so should work with them all. But same socket does not mean much as far as compatibility goes. That is what I was thinking. I will probably contact ASRock tech support to see if it will work. Thanks for your answer. Upvote 0 Downvote
