Will the EVGA GeForce RTX 2080 SUPER FTW3 HYBRID GAMING fit inside the Lian Li PC-O11 Air? I am worried that the tubing will get in the way of closing the side panel, and even if it fits, will cause too much pressure on the tubing for the AIO cooler.
I all ready ordered both of these parts for my new build. Now I'm getting nervous about the GPU dimensions because I don't think they included the tubing coming out of the GPU. I looked up an equivalent air cooled EVGA RTX 2080 SUPER FTW3 and it had the exact same dimensions listed.
https://www.evga.com/products/product.aspx?pn=08G-P4-3288-KR
GPU: Dimensions Height: 5.48 in - 139.3 mm Length: 11.45 in - 290.83 mm Width: Dual Slot
www.lian-li.com
Case spec for VGA Card: length ≤420mm , height ≤159mm
The motherboard height might affect the final fit, but I'm not sure how to evaluate it until I get the parts... I'm just wondering if I should return the case when I get it in the mail, or open it up and try the build to see if everything fits...
(Here is my parts list: https://pcpartpicker.com/list/BvpRsk)
PC-O11 AIR – LIAN LI
