Will the EVGA Geforce GTX 780ti (Nvidia Model) Be enough? - Please help
Mads Haugaard
246
Hi.
I wanna upgrade my system and gaming gear. Im going to buy the 780ti but i was wondering if it could run with this monitor?
I got a Core I7 5820K too.
ASUS MX299Q 29-Inch Ultra Wide LED-Lit Monitor (2560 x 1080)
Thx for answering asap. And sorry for bad english.
I agree, get the GTX970. I specifically recommend the EVGA ACX 2.0 1.17GHz model which is $350 (see pcpartpicker).
http://pcpartpicker.com/part/evga-video-card-04gp42974kr
Similar performance, more memory, new features and runs much quieter; in fact the above card will even turn off the fans in light usage. Also a lot cheaper as well so it's idiotic to buy a GTX780Ti which is possibly $200 more expensive.
And YES it will run the monitor just fine.
However, your frame rate in a game totally depends on the game and your settings in the game. You can even use a lower resolution but I can't think of a game where you wouldn't want to use 2560x1080 with a GTX970.
http://www.techpowerup.com/reviews/EVGA/GTX_970_SC_ACX_Cooler/25.html
Performance is basically IDENTICAL but again:
- cheaper
- quieter
- uses less power
- more VIDEO RAM (4GB vs 3GB)
- has new features (H.265, HDMI 4K 60FPS support, MFAA, Dynamic lighting Voxel support)
You'd need to charge $300 for the GTX780Ti to make sense...
**Note that this links is NOT for the card I recommended above. The one I recommend uses the ACX 2.0 fan setup which is quieter.
Okay.. Thx alot but ive heard that the 970 is not the best card in some ways that it drops in fps?.. but anyway i was wondering if the 980 would do even better?
EDIT:
And Btw i think that cooler (acx) dosent looks very nice :/
