Will the Geforce GTX 950 Fit in a dell optiplex small form factor case?
Reis
Commendable
Jul 31, 2016
So i need a new Video card to play dead by daylight and other intense titles.
I also need a prosesser upgrade but i only have money for a GTX 950 right now.
I need to know if it will fit in the sff case and if it is compatible
Here is a link to the one i want
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487156&cm_re=geforce_gtx_950-_-14-487-156-_-Product
And also if anyone knows if this is compatible than tell me
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284&cm_re=8_core_processor-_-19-113-284-_-Product
My model is the Optiplex 760
The video card i have right now is the ATI Radeon 3450
If i need a case upgrade and/or a motherboard upgrade please post a link to the cheapest i can find
Thanks - Reis
There were 2 different MB for the 760 one is limited to 2 core CPU and the other supports Core2Quads. The GTX950 requires a 6 pin PCIe cable that your PSU won't have. Get your Dell MB number and search CPU support. If it supports any quads then Q9650 is the biggest, Q9550 is popular. If 720p resolution is OK for you then a GT730 1GB DDR5 card will work well also. With MSI afterburner a 25-30% overclock is possible and video benchmarks in the mid 30fps on high/ultra are possible. If you could swap it for a Mid Tower with Core2Quad support life would be easier. Then heatpipe coolers, biger PSUs , and full height video cards would be possible.
its an optiplex 760
SFF are limited to single slot low profile gpu's
best you can get is a gtx 750 ti like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127836&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Video+Card+-+Nvidia-_-N82E16814127836&gclid=Cj0KEQjw57W9BRDM9_a-2vWJ68EBEiQAwPNFK2cJWOtP5kxsQbLjI4pjGDo4aXbavsZzM3oFcPZsxFsaAsjE8P8HAQ&gclsrc=aw.ds
also that processor wont work
the 760 comes with a core 2 duo ( maybe core 2 quad )
