J Just-interestedindacomputers Reputable Oct 9, 2015 5 0 4,510 Oct 9, 2015 #1 I just bought a new case and wondered if the corsair h110 fitted in it it's called the green goblin mesh gaming case if it does not fit what other water cooling case would anybody recommend for overclocking
Solution ak47jar3d Oct 9, 2015 No, it will not fit. Corsair Hydro Series H80i GT Performance Liquid CPU Cooler CW-9060017-WW https://www.amazon.com/dp/B00SV7IIDU/ref=cm_sw_r_other_awd_X0-fwbZ4FA78Y
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,817 1,871 159,590 Oct 9, 2015 #2 It won't hold a h100i. Upvote 0 Downvote
ak47jar3d Champion Mar 3, 2014 7,231 99 54,590 Oct 9, 2015 Solution #3 No, it will not fit. Corsair Hydro Series H80i GT Performance Liquid CPU Cooler CW-9060017-WW https://www.amazon.com/dp/B00SV7IIDU/ref=cm_sw_r_other_awd_X0-fwbZ4FA78Y Upvote 0 Downvote Solution
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,817 1,871 159,590 Oct 9, 2015 #4 It's a budget case , not really for high end cooling. Upvote 0 Downvote
J Just-interestedindacomputers Reputable Oct 9, 2015 5 0 4,510 Oct 9, 2015 #5 Thanks for the answer I will get the corsair h80i Upvote 0 Downvote
