Here are some images of my case - a Diabolic Minotaur - my current cooler (Akasa AK-CC7117EP01 K32 High Performance Intel Cooler for LGA775, LGA1156 and LGA1155 ) can be clearly seen
Looks OK from that I'd say, but then on the side panel there's this big green filter thing that goes directly above the heatsink and looks as though it'll definitely get in the way:
There are some screws - it is removable. Do I really need this thing, or can I safely remove it in order to fit a Hyper 212 Evo?
I'm getting an Intel Core i5 4670K 3.40GHz as part of my forthcoming upgrade. I'm not ruling out overclocking it further down the line which is why I'm looking at the Hyper 212 Evo. If it won't fit, will my current cooler be OK for now - will that be better than the stock Intel cooler?
My case's measurements approx:
45cm Height,
50cm Depth,
20 cm Width.
If the Hyper 212 won't fit, do you guys have any suggestions as to an alternative?
Thanks in advance.
Edit: Here's a review from Amazon on my current cooler with my intended CPU:
If I could stick with my current cooler it'll save me a lot of hassle and £20 or so as well.
45cm Height,
50cm Depth,
20 cm Width.
Thanks in advance.
I am using this fan with an Intel i5-4670k @ 3.40ghz. I haven't overclocked (yet) but i'm sure i'll be able to with this cpu fan without the cpu overheating.
The temperature when idle is usually around 28-30 degrees celcius, but after gaming for a few hours on the highest settings the temperature maxes out at around 50-55 degrees, which is much lower than what the stock cooler would provide.
Overall, i would recommend this to anyone who wants a cheap CPU cooler for a budget build.
