Will the MSI B85 LGA 1150 usb 3.1 micro ATX Motherboard (B85M-E45) run my system?
Loyde Kessroy
Commendable
Apr 11, 2017
69
I found this while looking for a cheap mobo and I need to know if it will be able to run my msi gtx 1060 6b gaming x.
Also, what are the cons of it and is it not compatible with anything useful for a gaming PC? I plan to use this only for a few months and I can buy a completely new setup. Thankyou.
It will run the card no problem. It has the required slot and with compatible CPU and good enough PSU it will do fine, its the GPU and CPU that define gaming performance not so much the motherboard.
