Yes at least in PCPartPicker says that fits, might be tight and cable management will be worse but it will fit.
Looking at some photo's do i still doubt it.The top fans are already on top of the motherboard so a radiator together with those,imo,wouldn't fit.
Filipe Mata :
He might want to use the 3.0 headers, i just pointed out.
He would have to use an expansion slot card to that makes use of it if he had one.The case doesn't matter since only using usb 2.0. Usb 3.0 might not even matter anyway if the version of the "m5a97" the OP wants to use doesn't even have a usb 3.0 header.
