R Ryan Cernicky Reputable Oct 12, 2014 47 0 4,530 Oct 14, 2014 #1 Do you guys think this psu will work?http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.1763591
Solution bignastyid Oct 14, 2014 Psu isn't very good, should be advertised as a 400w unit. The biostar motherboard is junk.
G Guest Guest Oct 14, 2014 #2 i doubt may or may not be.....amd components tend to draw more power than specified.. Upvote 0 Downvote
G Guest Guest Oct 14, 2014 #3 i doubt may or may not be.....amd components tend to draw more power than specified.. Upvote 0 Downvote
Zerk2012 Titan Ambassador Oct 6, 2014 22,332 2,407 104,240 Oct 14, 2014 #4 It is enough power but really poor quality. Upvote 0 Downvote
bignastyid Titan Moderator Jun 19, 2011 33,688 1,700 159,590 Oct 14, 2014 Solution #5 Psu isn't very good, should be advertised as a 400w unit. The biostar motherboard is junk. Upvote 0 Downvote Solution
R Ryan Cernicky Reputable Oct 12, 2014 47 0 4,530 Oct 14, 2014 #6 What PSU would u guys recommend Upvote 0 Downvote
