Question Will the Radeon RX 570 8GB Nitro+ fit in my case?
InfinityVive
Great
May 23, 2019
109
4
85
So, the Radeon RX 570 8GB Nitro+ that I ordered will finally arrive tomorrow , But I am wondering if it will fit in my case, I am using Dell optiplex 7020 with a core i5 4590, 8 GB RAM, 550W Crosair PSU, Will it fit in? The case tower is like this: https://www.amazon.com/Dell-OptiPlex-7020-Desktop-Computer/dp/B00M1C4JFC/ref=mp_s_a_1_16?keywords=dell+optiplex+7020+tower&qid=1560394544&s=gateway&sr=8-16 , And here is the GPU: https://www.amazon.com/Sapphire-11266-09-20G-Radeon-Backplate-Graphics/dp/B071XNH5BC/ref=mp_s_a_1_5?keywords=nitro++rx+570+8gb&qid=1560394820&s=gateway&sprefix=nitro++rx+570&sr=8-5 , And here is the PSU: https://pcpartpicker.com/product/FdRFf7/corsair-cx-2017-550w-80-bronze-certified-atx-power-supply-cp-9020121-na , Also I am using a 24 Pin to 8 Pin PSU adapter to use that PSU, So is everything good and compatible?
AllanGH
Commendable
Mar 10, 2019
1,704
320
1,640
48
Supposedly, at least according to Amazon, the card is 12.75" long, and 8.5" high. I wonder if that's actually the packaging. I've never seen a card that is actually 8+" high, even including the entire length of the slot bracket plate.
Get a tape measure and measure the available front to back space, where the card will be slotted, then the headroom over the motherboard. LOL...if the package will fit in your case, the card certainly will.
InfinityVive
Great
May 23, 2019
109
4
85
I want a yes or no not telling me to measure my case and package that didn't arrive yet... : /
AllanGH
Commendable
Mar 10, 2019
1,704
320
1,640
48
I'm sorry that I can't give you a "yes" or "no" to your question when you don't want provide that answer for yourself by making case measurements--which you are certainly capable of doing.
It would be best if you research your next purchase BEFORE actually buying the product.
Reactions: King_V
USAFRet
Will it fit that case?
Unless you find someone with that exact same combination, all anyone can say is "Probably".
The 570 is not unusually large, and the case is pretty medium size standard.
Of far more concern is:
"Also I am using a 24 Pin to 8 Pin PSU adapter to use that PSU, "
With compatible components, an 'adapter' should not be needed.
Others have also voiced concerns:
Reactions: King_V
InfinityVive
Great
May 23, 2019
109
4
85
Well. Oof, I will not be able to sleep today because of worrying too much about if the Video card is compatible with all parts in my PC and will fit in, Thanks all for not giving me the answer I want : /
Similar threads
