racisthooligan :
GRUxTSAR :
Not sure about Raijentek's reliability, but I've heard some horror stories regarding the H100i. You could always go with a custom loop for $200 with compression fittings if you really want to be safe. Custom loops are as safe as you make them while AIOs you have no control either
thanks man whats some good reliable custom builds??
Well with custom loops, you have to get parts and build it yourself. Not something I'd advise without doing your homework on, big time. You can read the Tomshardware watercooling sticky and go from there with research. XSPC makes some watercooling kits that have everything you need to create a custom loop, but I'd still advise you to at the very lease read the whole watercooling sticky so you don't mess up your custom loop.
