Will the RM850 power this build, or do I need more?
Grolthok
Pretty much the title. I keep second guessing myself and looking at power supply calculators and can't figure out if I'm over thinking it or not.
Case: Fractal Design R2 XL
Mobo: Gigabyte GA-Z87X-UD5H (board SATA power plugged in)
Memory: Corsair XMS3 4x2GB (possible upgrade to 4x4 Dominator or Vengeance in the future)
GFX: 2x (SLI)Gigabyte GV-N770WF3-2GD GTX770 (may go with the GV-N770OC-2GD. Same price, but overclocked. Not sure on that yet)
CPU: Core i7 4770k
SSD (boot): Crucial 500M 120gb
HDD (storage): 1.5TB Seagate Barracuda 7200.11 ST31500341AS (may upgrade later to 2TB+)
Optical drive: Standard SATA DVD +-RW
Cpu Cooling: NZXT Kraken X60 (Possible Push/Pull setup using 2 more NZXT FX-140LB 140mm fans) (Fan controller SATA power connected)
Case Cooling: 3x 140mm Fractal Design FD-FAN-SSR2-140 (Replacing all fans with Rosewill ROCF-11003 Hyperborea's x7 when I can)
USB Devices: 1x Plantronics Gamecom780, Mouse, Keyboard, occasional charging ports, webcam as needed for streams, etc.
It just seems to me that 850w is just low. Or maybe I'm overestimating things.
