Will the rx480 power this monitor
computerwonder
147
I've found a monitor that I'm looking at however I'm undecided if it will power it or not.
Acer Predator XZ350CU
If I can't power this monitor would someone be able to point me in the direction of a good ultrawide (curved if possible) monitor.
Kind regards
Matt
it will work fine.
Just don't expect everything to run over 100FPS on highest settings.
AMD have no video card yet that can do that.
If this monitor for gaming purposes only, it's fine. If you use it for other things, it's kinda low resolution.
a good monitor would be 3440x1440 (like dell U3415W, Acer XR341CK) but they are kinda expensive and require at least GTX 1070 for gaming with high settings on full resolution
it will work fine.
■ thanks for the reply . Just out of Interest say if I use it for world of Warcraft. I'm getting 60fps on my current monitor 1920x1080p 50-60 fps everything maxed out. Could I achieve the same sort of result on this monitor. Once again thanks for the help
