Will there be a bottleneck in my system?
balint111
37
Motherboard: Gigabyte 780T-D3L
RAM: Kingmax DDR3 8 GB 1333Mhz RAM
CPU: AMD FX-4100 ~3.6 GHz
Graphics Card: Nvidia GeForce GTX 760 WindForce 3X OC Edition
PSU: SEASONIC S12 II 620W
I'm running 1080p.
It's probaby the CPU, right?
Quite big. the 4100 is a really weak quad core cpu. Core for core it cannot keep up with intel's offerings. I would suggest upgrading the cpu/mobo to an intel core i5 build (you can keep the ram, and the psu. You could get an asrock mobo and an i5 4570 for a relatively small amount of money. I would put the money towards that before buying a good gpu.
Really right now you should go for an entry level AMD Piledriver CPU.. maybe if you wanna play around with OC (please.. read guides, do your homework) buy a Hyper-212 on the side.
If you get a FX-6300 you should be able to push it up to 4 Ghz and there is some, although little, evidence proving that 6 cores is supported in future gen games (fx BF4).
You will get more bang for your buck this way..
