Will there be any problems if I use a 460w PSU with a GTX 1060 6GB GPU?
Jul 21, 2018
4
I purchased a GTX 1060 6GB GPU and I want to know if a 460W PSU will support it. I know the consequences of not having a powerful PSU that can support a strong GPU so I just want to make sure.
-Thanks
The model seems to be built by Delta, and used in HP prebuilt PC's.
This says it is pretty good: http://www.tomshardware.com/answers/id-1894877/question-friend-psu.html
But, I would not trust it because it is quite old and not reliable as well as it has no certification. Get a new unit.
Try these:
Power Supply: EVGA - SuperNOVA G3...
CPU: Intel Core i7-4700 3.40Ghz
2 Drives: "Windows (C)" and "Recovery Image (D)" (Both should have a collin but it wouldn't work)
My CPU is overclocked
My PSU's model is DPS-460DB-5A
The test recommended me PSU's with 550W PSU's but I want to know if the upgrade is necessary because the GPU already was a lot of money
Try these:
Power Supply: EVGA - SuperNOVA G3 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($49.99 @ B&H)
Total: $49.99
Generated by PCPartPicker 2018-07-22 21:50 EDT-0400
Inexpensive REALLY good PSU.
OR
Power Supply: Corsair - CX (2017) 550W 80+ Bronze Certified ATX Power Supply ($32.98 @ Newegg)
Total: $32.98
Will get the job done for now.
yes and no.
if you have an older system (im talking prolyl 10+yrs old) then yes.Older systems used a different PWR adapter to connect to components.
However most now-a-days use the sata interface. (actually not even sure if they MAKE older type psu anymore).
Ok I finally installed my new graphics card and it works. This is only the first hour of it working, I dont know if anything will change in the coming hours but thank you for your replies and suggestions. I used the EVGA - SuperNOVA G3 550W 80+ Gold Certified Fully-Modular ATX Power Supply. Thanks for helping me!
