[SOLVED] Will there be compatibility problems with these ?
Lyelyei
6
Hello buying new parts for my pc and i wonder will there be compatibility problem with these parts ?
intel i5 -9600k
HyperX Predator DDR4 RGB 16GB kit 3200MHz
MSI MPG Z390 GAMING PRO CARBON
pcpartpicker.com is an easy way to find out if there will be compatibility issues with parts adding onto a build. If you put everything there, it will give you a list of user-reported issues if there are any. There won't be problems with those parts, but just a little tip if you plan on upgrading often.
