Will Thermaltake Litepower 450W be enough for my system?
Fardin123
11
Hello, I'm planning to buy a new setup. Here are my specs:
Intel Core i5 8400
Asus Strix Z370-F motherboard
Cooler Master Hyper 212 LED CPU Cooler
Zotac GTX 1060 AMP Edition 6GB Graphics Card
8GB G. Skill TridentZ RGB
3 RGB Front panel fans (the case is Cooler Master Mastercase Lite 5 RGB)
I already have the case and the power supply of my old setup (Thermaltake Litepower 450W)
Will the psu be enough for my setup??
If you like your system don't get that PSU.
I recommend getting a higher quality unit.
A PSU is NOT the place to cut costs as you could lose you whole PC.
The PSU is the most important part of the computer.
I would not reuse that power supply with the new parts you can get a decent one fairly cheap depending on where you live.
Example in the US.
https://www.newegg.com/Product/Product.aspx?Item=N82E16817139146&ignorebbr=1&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
https://www.superbiiz.com/detail.php?name=PSS12II520&c=CJ
