I've got a decent list of parts for my build but I'm worried that I'm cheaping out on the case fans. I intend to do a little video editing and occasional 3D rendering, so it might get a little toasty now and again.
INTAKE:
The three stock fans that come mounted to the front of the Phanteks P400a D-RGB. I'm struggling to find what make/model these are so can't post specs. I'd love to hang on to these as it's what made me like the case, but if they're crappy them I could upgrade later.
EXHAUST:
I was given a couple of fans for free which I plan to use for 1 rear and 1 top exhaust. GameMax Razor. They're cheap! This is them:
http://www.gamemax.uk/index.php/products/cooling/razor-12cm-argb-fans/
Advertised specs (and they say they are PWM):
QUESTIONS:
INTAKE:
EXHAUST:
Bearing Type: | Hydro Bearing |
Fan Speed: | 1200rpm ± 10% |
Max. Air Flow: | 60 CFM |
Max. Static Air Pressure: | 2.01mm-H2O |
Noise Level (max.): | <26 dB(A) |
QUESTIONS:
- Would I get worthwhile gains by upgrading the case fans (especially the rear and top exhaust)?
- CPU cooler is the Dark Rock 4 (non-pro) with single fan pushing air across. I'm a little worried that the tall heatspreaders on my Corsair Vengeance Pro RGB will be partially covering the fan. Will this be a non-issue? Is it worth adding a second fan for push/pull?
- Should I consider any additional cooling not mentioned above?
- ASUS Tuf Gaming X570-Plus (Wifi)
- Ryzen 7 3700X
- 32gb Corsair Vengeance Pro RGB
- Patriot Viper VPN100 M2 NVMe 1TB
- Sapphire Radeon RX 5700 Xt Pulse 8GB
- Corsair RM750x
