[SOLVED] Will these components be compatible with eachother?
Dec 10, 2018
23
I’m planning to get the b350 gaming plus micro atx mobo, a ryzen 7 2700, 16gb crossair vengance 3200mhz ram, and a amd radeon 580 armor 8gb oc. Will there be any compatibility issues or bottlenecking?
Get a B450 chip set motherboard. That will be natively compatible (doesn't need a BIOS update) with the second generation Ryzen 7 processors.
-Wolf sends
Are there any B450 mobos under 105$ you would recommend?
