Will these components fit in a HAF 922?
-Naz-
29
Hello Guys I have decided to put this system together, and I am not interested in waiting for any of the new GPUs or CPUs that are coming out soon. I just want to know whether the following components will fit into a Cooler Master HAF 922 case, and whether they are all compatible together. So please help me out and inform whether they will, here are the components:
CPU: i5 2500K
GPU: I have many in mind, just tell me which will fit and which won't.
6950, 6970, GTX 570, 7950 and 7970.
RAM: G.Skill Ripjaws X F3-12800CL9D-8GBXL 8G Kit(4Gx2) DDR3 1600
HSF: Cooler Master hyper 212 EVO
PSU: Corsair HX850
Motherboard: ASUS P8Z68-V GEN3 Z68 DDR3 Intel 1155pin Motherboard
Case: Cooler Master HAF 922
Thank you very much, and like I said please only inform me whether these components are compatible which from my understanding are, and whether they will fit into the HAF 922. Will the power supply fit in, and will the G.skill ram at all interfere with the EVO Heat Sink Fan or will there be an enough of a clearance for it.
Once again Thank you.
Everything will fit perfectly. I have the little brother HAF 912 , Zalman Perofrma CPU cooler, 6950 video card and i have a lot space inside.
Maybe you will have problems with the RAM heatsink and cpu cooler. Buy low profile memory.
Mushkin Enhanced Blackline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 http://www.newegg.com/Product/Product.aspx?Item=N82E16820226191
G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231416
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233196
hellfire24
Splendid
922 is a great case.it will fit your setup.
CPU: i5 2500K
PSU: Corsair HX850
everything is great.for gpu go with 7950 and overclock it.it's more than enough for 1080p.go with HX750w,it's more than enough for 7950 CFX.922 is great.
-Naz-
29
Thank you all very much for your responses. Its great to know that the HAF 922 will fit everything comfortably, and considering no one mentioned anything about the parts being incompatible, im going to assume that they are all compatible.
I guess I can go with these Corsair low profile http://www.onlinecomputer.com.au/product_info.php?products_id=8786, as the have the same speed, and are the same price, to ensure the HSF clears the RAM nicely.
Thanks for suggesting the HX 750 being able to take a 7950 Xfire, but im going with the HX 850 because there is a really small difference in price where I live in Australia between the two, so I'd rather pay the $5 extra, as everyone would if that were the price difference.
-Naz-
29
Hey guys, i went out and bought these components but want to do one final check as to whether the following components are compatible and will fit into a Corsair Carbide 400R case (Changed it from a HAF 922) before opening everything up. These are the components so please just let me know:
CPU: i7 2600K
GPU: Sapphire 7950 OC edition (Dual fan)
MB: Asus p8z68-v pro/gen3
PSU: Corsair HX 850
RAM: 8GB Corsair Vengeance Low Profile 1600Mhz
Case: Corsair Carbide 400R
Please let me know if they will fit in the case and are compatible, so that I may start putting it all together.
Thank you.
Silvune
Splendid
Yes they are compatible and everything will fit in the case.
The graphics card is 27.5cm long, the case can take GPUs up to 31cm.
The Hyper 212 Evo is 15.9cm tall, the case can take CPU coolers up to 17.5cm.
Similar threads
