Will these components "satisfy" my GTX 1070?
NaughtyDoggie
Commendable
Jan 8, 2017
4
Hey guys!
I have a Gigabyte GeForce GTX 1070 8GB G1 Gaming videocard, but my pc specs bottleneck it.
I came up with these parts to buy thus solve this problem:
-Intel Core i7-6700K 4GHz Socket 1151
-Gigabyte GA-Z170-HD3 motherboard
-16GB 3000MHz DDR4 RAM Corsair Vengeance LPX Red CL15 (2x8GB)
Could there be any further problems if i go with these parts?
Is there a cheaper, lasting solution?
Answers much appreciated!
Yes, you should be good to go with those parts. You could probably save a bit on the CPU, but long-term you'd be shooting yourself in the foot if you are not planning to upgrade in a year or two.
Looks like a nice system! What are you thinking for a case and cooling?
Thank you! Well i have a pretty powerful and quiet corsair air cooling system ( back then i had AMD so it will do the job im sure) and a zalman case with some pretty red lighting. :)
